Electric Discharge Machines (EDM) affect on material
Hello all!
Just curious as to if anyone is aware of the affect of EDM's on materials, particularly steel. I heard that it interferes with the grain boundaries. Is this true?! I receive work from two suppliers, identical material, but one produces it under mass production conditions and the other in a specialist unit. The properties, following a heat treatment at my plant are varying and sometimes they are identical but at other times the mass produced ones are of a poorer quality. I believe they may be rushed during cutting, does this result in burning similar to a standard saw? I'm not used to this equipment so not sure of whats going on! Thank yoy for your time!
CP
CP
RE: Electric Discharge Machines (EDM) affect on material
hth
nick
www.td.co.za/edm.pdf
