combining number formats
I apologize if this is too basic.
How do I combine multiple number formats for single cell
0;-0;;@  (ignore zero's)
#,###  (add comma's)
RE: combining number formats
Pete:
More than one number for a single cell?
You can apply different formats for characters in a single cell, but if you put a number it will be recognized as only a number.
If you want to put more than one number with different formats, you may only do it if you declare the cell as a text. You may do it adding the apostroph ' before the number. If you want ot have it centered, add the character ^ before the number.
It will be taken as a text, and you may format the cell character by character.
Best regards
J.Alvarez
Try this (code shall be in the specific sheet):
Private Sub Worksheet_SelectionChange(ByVal Target As Excel.Range)
' two number formats for a single cell
With ActiveCell
  If Not IsEmpty(.Value) Then
    If IsNumeric(.Value) Then
        Select Case .Value
            Case Is < 1000
                ActiveCell.NumberFormat = "0;-0;;@"
            Case Else
                ActiveCell.NumberFormat = "#,###"
        End Select
     End If
  End If
End With
End Sub
Hope it helps
_LF
Thanks Palusa.  I think that is exactly what I need.
One small problem. I am not smart enough to figure out where to put the code or how to execute it.
Can someone please explain that part?
That is a very important question electricpete. I usually put my codes in a "module". Putting them anywhere else gets me into a maze of problems(problems here means no problem since there is simply no action)
respects
ijr
OK. I know where to insert it as follows:
   went to tools/macro/vbe.
   Insert/module.
   Cut pasted into the module:
   With ActiveCell
           Select Case .Value
               Case Is < 1000
               Case Else
           End Select
        End If
     End If
   End With
   End Sub
  Close and Return to excel.
How do I execute it?
I think I have figured out how to accomplish this without vba code.
1 - Set all cells to number format #,###
2 - Format/Conditional formatting, If cell value = 0 , Then set set format font-color=white.
But if anyone can explain how to execute a subroutine above I would still be interested.
Yeah electricpetet
I dropped by here to let you know of conditional formatting and to cancel out my earlier post on where your vba should be. Palusa told you actually that you should write your code in that specific sheet and he is right.
I keep functions in modules but I think subroutines are more sensitive to where you store them because they deal with more cells and they produce an action effecting a range of cells, while functions simply return a value.
 For this particular sub, reference is made to the sheet you will process. So first keep in mind the name of the sheet you are storing data(say sheet1), then switch to VB window, in the folder area there(usually on the left) double click the "sheet1" and the code window(usually on the left) should read "worksheet",paste the code or write it on there. Then switch to excel window and type in numbers some less than 1000 and some in excess, and there will be some action everytime you move to a different cell. I tried it and it worked(though I dont know what the theme is).
respects
ijr
Hi electricpete,
apologize i was out of office & couldn't get your msg.
To activate the macro i gave you:
(1) open VB (alt F11);
(2) within the VBA project panel, locate your working file: normally you have a structure such as: "(-)VBA Project (MyProg.xls)"... and below... "(-)Microsoft Excel Obiects" ... and below "Sheet1 Sheet2 ... ThisWorkbook".
(3) Select the sheet where you want to apply this formatting by doubleclicking.
(4) In the code panel paste the routine i sent.
VoilĂ , you don't need to activate it: it will run in background because it traps any change in the worksheet (try it).
Of course if you intend to apply in other sheets of the same workbook repeat the above steps.
Hope it helps
_LF
I apologize if I have completely missed your point, but have you tried this format:?
Not sure whethre this is helpful, but two different formats for one cell I did once was a CUSTOM FORMAT entered like this
[>=1000]#,###;###.0
Hope this helps.
maybe only a drafter
but the best user at this company!
