Steering and Suspension Courses
Dear all,
Currently I am working for a company which develops rubber to metal components. We are currently developing almost every rubber to metal part in the car (top mounts, bushings, stab bar bushes, hydro bushing, engine mounts, ...). Our customers are pushing us to analyse Road Load Data. I would like to be taught in suspension dynamics.
If you know any good course about the above topics, please let me know.
Thanks in advance for your help.
David Bayo
David Bayo
RE: Steering and Suspension Courses
What sort of road load data are you going to analyse? In which software? With what purpose in mind?
Here's the way several companies do it:
http://www.smartsim.org/Documents/Daimler_Chrysler_Road_Loads.pdf
Cheers
Greg Locock
In fact I am involved in two project in which at the end of the day our customer requires the same. It is to predict rubber to metal parts life.
One of our customers gives us the load in our part, so no problem with that (that cases are simple for us). In other case the customer gives us pieces the information, like road load data, measure point, link's geometry, ...
According to our customer we need to analyse dynamically the suspension in order to determine our part's load. After that it is possible to develop, by testing and statistics, a simple test (using our part only, perhaps a link in other to intrude torques in our part easily) which produce similar failure modes.
Until now this is the main service we must provide to our customer. We are currently using I-Deas 10 (internal solver), if necessary I can use an Adams external license (just to solve the problem).
Our experience in dynamic simulation is limited to the front control arm, in a McPherson suspension.
Hopefully I have clarified a little bit my situation. Please, let me know what you think about that.
dbmi
You will need your ADAMS license, and a model of the suspension (their responsibility, IMNVHO, unless you are a tier one).
What module of ADAMS are you using? I am only familiar with the road load process in APRE, but basically you apply the load set to the input points as defined motions and forces, and the solver then generates forces and deflections in other parts of the suspension.
Cheers
Greg Locock
http://www.motec.com/semnars/claude_seminars.htm
http://www.optimumg.com/
-Dave
http://www.moslerauto.com
"Everything should be designed as simple as possible, but not simplier"
