Sub assembly problem
I have a subassembly which shows rebuild errors while in the next higher assembly. When I open the subassembly it shows no error. Also when I conduct a mass properties execution I recieve no data except for the location of the CG. Has anyone run into this before. I have cleared my temp file and repaired the installation of 2004 sp3. Thanks for any help.
RE: Sub assembly problem
Are you sure you are not saying "no" to updating the assembly when you switch back from the subassembly?
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There's no place like 127.0.0.1
