Gauge R&R on Vickers Hardness
I'm not sure if it's feasible to perform Gauge R&R on Vickers hardness measurement. Could any one provide me some advice or guideline. Thank you.
Best regards,
ct
RE: Gauge R&R on Vickers Hardness
http://www.asminternational.org/Template.cfm?Section=ASMArchives&template=JournalAbstractDetail.cfm&AbstractID=7335
Also, NIST has a guide to the Rockwell test, NIST SP 960-5: Rockwell Hardness Measurement of Metallic Materials, that may provide some guidelines for you. It is available at:
http://www.metallurgy.nist.gov/publications.html
Cory
Hi swall, I'm refering to Vickers microhardness 0.3kg.
Best regards,
ct
http://www.hardnesstesters.com/brinell-scanner.htm
I know that Instron (Wilson) and Clemex both offer automated image analysis for use with microhardness testing. You would need to talk to them about gage R&R. I recommend contacting Ed Tobolski at Instron for more information. Use the following links for more information:
http://www.instron.com/software/autotest.asp
http://clemex.com/Products/MicroHardnessTesting/Automatic.aspx
