Bearing Frequency Calculator
I am looking for an ACCURATE calculator software supplier for bearing frequencies. I currently have The Bearing Expert from International Source Index Inc. and am finding some serious descrepencies with between it and manufacturers info. i.e. - # of rollers,dimensions, etc.
Any suggestions?
Any suggestions?
RE: Bearing Frequency Calculator
Alex
for FAG bearing contact :
http://www.fag-industrial-services.com
there are friendly
1 - bearing manufacturs may periodically change their bearing designs slightly. The SKF6308 that you buy today may not have same fault frequency as the one installed in your pump 5 years ago.
2 - Bearing fault frequency depends upon contact angle which in turn may depend on loading. Can change for example with changing load on a pump which changes the axial load on the bearing.
3 - Extreme wear can have a slight effect.
