Subgrade Building Waterproofing
I am working on a project involving a building that was constructed in the early 80's. The building is located near the base of a hill that reportedly perpetually had water seeping out of it. The building location was reportedly swampy, highly organic. The soils within the hill and the surrounding geology are clayey with some small (<1") sand seams.
We installed several piezometers around the building and identified static water at up to two feet above the elevation of the floor slab. We also saw primarily clay with sand seams in the borings.
Currently, the building experiences water infiltration problems, primarily in the Spring and Summer and after rain events, but at other times as well. My question is what have others used as waterproofing or water control options on a retrofit project. I have discussed installation of a new sheet waterproofing (Paraseal or similar) system and drain tile outside the building, but it will be extremely difficult and expensive to install. I appreciate anyone's thoughts and comments
RE: Subgrade Building Waterproofing
