Corrosion Fatigue vs. Stress Corrosion Cracking
Hi all.
This is a continuation of a similar thread that I started...
(don't know how to insert a thread link)
Is there a difference between corrosion fatigue and stress corrosion cracking? - I am familiar, (thanks to you guys) with SCC.
Thanks in advance
tg
Thanks in advance
tg
RE: Corrosion Fatigue vs. Stress Corrosion Cracking
yes. Generally speaking, corrosion fatigue in most metals can be characterized by crack propagation that is typically transgranular (thru grains) with minimal, if any, primary crack branching. You could possibly see corrosion products along the primary crack surface and near the crack tip.
SCC on the other hand typically exhibits noticeable crack branching with a crack path that can be either transgranular or intergranular (along grain boundaries).
Cory
http://www.corrosion-doctors.org/Forms/fatigue.htm
http://www.corrosion-doctors.org/Forms/scc.htm
See e.g. below
Thread330-94424
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
If it moves, train it...if it doesn't move, calibrate it...if it isn't written down, it never happened!
