AutoCad 2004 Toolbar Icons
My office has just changed from Acad 2002 to 2004 and a couple of "fussy" people in the office do not like the new look Toolbar icons, Fillet, Match properties etc..
To keep these people happy is there anyway, without individually changing each toolbar icon, that I can import the Acad 2002 toolbar icons into Acad 2004 ?
Many Thanks
Welshman
RE: AutoCad 2004 Toolbar Icons
Have you tried copying the entire ***Toolbars section from the 2002 mns file to the 2004 mns file?
Be sure to make backups prior to making any changes.
if the bmp file for fillet ect.. in 2002 has the same name as it does in 2004  you can just copy the 2002 bmp to the new location. and replace the 2004 version it will load it next time you start up.
Icons are embedded in resource dll files in the AutoCAD directories. You might have to "resource hack" each bmp icon and replace it with the old icons to get what you want. See http://www.afralisp.com/vbaa/vbadll.htm for reference.
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
