"(RD1)" Appears after dimension text.
I don't know why this is appearing but when I put dimensions in a drawing, the first dimension has "(RD1)" under it, the next one will have "(RD2)" and so on. What did I do and how do I turn this off?
RE: "(RD1)" Appears after dimension text.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
You probably changed it when you were playing with the "Linear Step & Repeat" Pattern problem you had.
