Q-Deck Capacities
Q-Deck Capacities
Does anyone have any information on the capacities of Q-Deck?? I am trying to analyze an existing Q-Deck roof for new loads, but I do not have the original drawings.
I know the dimensions of the deck, and can assume the minimum thickness (for starters), but I don't know the yield stress.
It's about 30years old.
CG
CG
RE: Q-Deck Capacities
What are ICBO reports?
I'm looking for design tables, similar to what VicWest produces. Span versus loading.
My span is about 30', with a loading about 100psf (or more). I haven't looked specifically at the loads, because I was looking for tables first.
The deck is 10" deep.
I don't have a manufacturer. Essentially, the client has pointed at the deck and asked if it works for the new loads!! If you don't have data for decks as large as 10" then I will try a few manufacturers directly.
Thanks for your help.
CG
Thanks anyway...
CG
