Double column design
I have a circular 600 mm diameter column which may need to be halved to accommodate an expansion joint.Obviously the column will become a semi-circular column and may become slender( am i right). Which book is the best to refer to.Can anyone help ? How would I design the foundation/pilecap?
RE: Double column design
For the caps, normally you don't see the expansion joint taken through the cap. Simply tie the columns into a common concrete cap as you normally would.
Carl Bauer
www.bauerconsultbotswana.com
