Where can I find this?
Normally this is used in the bike industry (fork). This is what I need to reduce my "workshop time"
Now we're welding inserts into a tube,but that's too much labor... So where can I find these "Starflanged nuts"? in all kind of sizes? or is it just made for the bike industry?
For a picture.
http://www.bike2build.nl/fotogroot/b2bnut.jpg
Kind regards.
For a picture.
Kind regards.
RE: Where can I find this?
I think, and hope, you'll only find them in bicycle sizes.
For the non initiates, you push them down inside the aluminium tube, and then put a bolt in from underneath (in the photo's orientation), then torque the bolt up, which spreads the spring steel star washer out into the tube.
Cheers
Greg Locock
http://www.loosescrews.com/index.cgi
Maui
http://www.carpin.com/connector.htm
Good Luck
pennpoint
Qube
