AB & Digit Switch
AB & Digit Switch
AB & Digit Switch
I have 1761 ab micro controler with 4 analog inputs need to Know if I can hook up a Digit switch to It for setting Timers.
In the software.
RE: AB & Digit Switch
Not sure what you mean by "Digit switch".
But you can certainly use an analog input to set the .PRE part of a  timer.
Are you considering to multiplex the signal somehow, so that you can set more than one timer with one analog input ?
