How to display objects on top of a raster Image...
Using Insert Raster Image,for autocad 2000.
Would like to know how to insert lines and other drawing objects on top of the inserted image such that they print in the foreground of the raster inserted image...
-dawn
-dawn
RE: How to display objects on top of a raster Image...
Modify - Object - Image - Transparency - select image frame and then select on or off.
Makes regens a lot eaiser also.
send to back
send in front ...
but, to be sure
1. place "image" as the first oject in you drawing
(if you can)
2. copy all except "image", then erase previous, this will
always have "image" "under" all Acad objects.
hope this helps
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Absolute zero has nothing on me!!
"_imageframe"
or "tframe" from Expresstools V 1-9
Lothar
ADT 2004
ACAD 2002
