Hot oil sample cooler(?)
I need to find some sort of 'sampler cooler' that is suitable for use on a Thermal Oil system.  The oil discharge temperature is around 500F and the MAWP is 150psi.
Any advice or possible suppliers would be greatly appreciated.
RE: Hot oil sample cooler(?)
Here is the one we used and found no problems with in sampling Therminol up to and including vapor at 700°F.
http://www.dopak.com
