Solid works graphics performance.
I am running Solid Works 2004, Service pack 0. Graphics Card is NVIDIA Quad 4 900 XGL.
I installed all recent drivers for the card.
I have the following problem: after I zoom OUT all my notes, dimensions, etc. became scattered all over the drawing or disappear. Some times Zoom fit does not work too.
After several zooms drawing looks normal again. Sometimes I have to quit SW and restart it again.
Does anybody know what should I do?
RE: Solid works graphics performance.
Computer is only few weeks old
Also, search this forum. There are a lot of threads about cleaning out files, etc.
Go to Tools\Options\System Options\Performance and check mark "Use Software OpenGL" - Do what you were doing to see if the problem persists. - If the problem goes away then the problem is your Video card or a driver issue.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
FAQ731-376
Thanks for the help
"Go to Tools\Options\System Options\Performance and check mark "Use Software OpenGL" - Do what you were doing to see if the problem persists. - If the problem goes away then the problem is your Video card or a driver issue."
Did it help you?
Did you try the Software OpenGL option I posted? If so, what was the outcome.
If not, why not?
Scott Baugh, CSWP
FAQ731-376
I have not seen a SP fix this sort of behavior. A Ctrl-Q should be used throughout the process of building a part, assembly or drawing anyways. If your stuck at 0.0 then how do you know that the SP will fix his problem? Do you have an SPR number you can post here on this type of behavior of double notes showing up when you save a file?
I have been using SW04 for awhile now and I have saved many drawings from SP0.0 and up. This issue has never shown itself to me. I'm not saying that's not happening to you. But if you ask me, that sounds more like a Video card or driver issue to me and not a SP fix. I might be wrong, that's why I ask if you have an SPR# for us?
What do you mean a ctrl-Q will fix it to print? Are you saying that if you do a print preview you see both notes?
Scott Baugh, CSWP
FAQ731-376
Thank you for help. I received more help from you in a day then from our IT department in the last week.
Open GL option is not avaliable in the Performance window, it is greyed out.
I upgraded drivers to the latest revision few days ago, and will use rebuild option more often.
I used UG before, so do not have a habit of using rebuild at all. I was using it only after I had a problem. How often should I use Ctrl-Q and why?
I will try to get an upgrade from local SW rep anyway.
Again, thank you all for help.
You CAN'T have ANY files open when you try to use that option. So you need to open SW (NOT A FILE in SW, JUST SW) then follow my instructions above.
A Ctrl-Q is just a deeper rebuild then the Rebuild icon in your Toolbars. The Icon only rebuilds the last feature.
Let's say your building a Complex surface model. As you build it and you only use the rebuild icon to rebuild your features. Sometimes I have seen it when you close and reopen the file that there are errors in the model that were not there earlier... Why? Because something failed in the process but didn't show itself. Why? Not sure about that one, but if the user would have done a Ctrl-Q. SW would have went to the top of the tree and rebuilt each sketch and feature all the way to the bottom. Then the error would have been seen and the user could have repaired it then.
Closing and opening the file right back and finding errors is not so bad. Try making a file and comeing back a few months later to find errors? Then try to repair it... not fun... Been there a few times myself.
Scott Baugh, CSWP
FAQ731-376
The spr is 190222
"Display of note text in this drawing document duplicates itself when drawing document is saved. It can only be corrected by CTRL-Q."
this is fixed in sp 1.0
If that's what your seeing sl99 then you need to upgrade. If you bought SW04 but no maintainence. You need to inform your Tech support that you are intitled to the latest SP because you have problem and there is an SPR#. You can give them this SPR# and they should send you the the latest SP or at least the SP that fixes the problem.
Do check your video card first, to rule that out. Using the "Use Software OpenGL" option.
Scott Baugh, CSWP
FAQ731-376
(Control Panel - Display - etc.....)
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There's no place like 127.0.0.1
To tell the truth I expected much better software package. I used UG before, and many things there are much easier to work with. From what I understand I have to create my own slot, under-cut groove, etc features. Creation holes for a circular clamp using a hole wizard is odd at best. I will attend class next month, may be it will help.
Unability to create a section of a detail on the view, or multiple bend sections is another thing that I expected to be avaliable.
Support is difficult, corporate office in the other state bought 12 or so seats. They did not buy a support option. So local sales office does not want to support me. I can not really blame them. Corporate does not help much either. When I was able to talk to local sales they blamed computer, and of course our IT blamed the software.
Sometimes I want software and computer guys to buy a new appliance or car and then pay additional 30% to the vendor for making it work right. Just seeing them calling transmission plant, then engine plant, then tire vendor, then assembly plant makes me smile.
I received more help from all of you guys then from Solid Works and our IT department combined.
Thank you all!
If your running better with "Software OpenGL", then your problem is with your graphics card.
http://www.solidworks.com/pages/services/VideoCardTesting.html?PID=383
http://www.solidworks.com/pages/services/SystemRequirements.html?pid=383
See if your computer passes these hardware requirements. Be sure you have a support video card and driver.
Scott Baugh, CSWP
FAQ731-376
shonico@hotmail.com
Your graphics card is not an approved one for use with SolidWorks, so that is why you are getting display issues. You could try to download the latest drivers for your card, but I think in the end you would be better off (happy) trying to purchase and use an approved card.
You can see which cards are certified for use with SolidWorks from the SolidWorks site.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
ht
Also, how did you upgrade SolidWorks? I hope you installed in a new directory as a separate installation instead of as an "upgrade". Upgrade doesn't work and really never has--it should have been removed from the list of options long ago.
If your card is rated OK by the SW site above, I'd recommend checking the FAQ section of this forum and consider a clean reinstall of SW per the FAQs if you attempted to use the upgrade option during SW 2005 installation.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
