plotting in ideas 10NX fails with MFC application error
We have installed Ideas 10 NX drafting on a windows XP pro workstation. The license file is still on a UNIX server as are the Team directories. The environment is an Active directory win 2000 server env.
Everything works fine except we can only plot as administrator and not as a domain user. We installed ideas with an ideasadmin who's also only a domain user. We made all users local administrators but also that seems not helpful. So I'm running out of ideas .... anyone??? thanx
RE: plotting in ideas 10NX fails with MFC application error
this might seem long winded but it works every time without fail.
Let me know if you can get the plot utility.
DOC
Likely that a directory created during the Instal by the Domain Administrator is not writeable by the local user/administrator. - I've found this to be a problem before.
My way round was to reinstall the software as the local Administrator.
Before you go to that trouble though, make sure you've specified a local "Start In" directory that the user has write access to to ensure that any temp files that are required can be written.
