Hepa filter leaks....Help
I have recenntly become involved in a Hepa filtration project and am having numerous "seal"failures when the units have been installed on site. The filters are equipped with a gel seal and knife edge. These however seem to be the source of the leaks. New gel seals have been installed with improved but similar failures. Are the other factors that can cause these gel seals to fail? Just seaching for ideas as i am out of repair ideas and the manufacture is currently of little help.
RE: Hepa filter leaks....Help
Also, what is the pressure differential across the filter. Once you reach a certain value, i.e. 2" w.g. or 500Pa, you may find that the gel seal will be forced out anyway.
friar tuck of sherwood
