REFERENCE SET HELP
REFERENCE SET HELP
I am using version 18 and have a rather large 3d assembly. All the sub-assemblies are controlled using the ref set "solid" to keep any unwanted datums etc out of the upper level. However, occasionally when i open my upper level assembly the sub assemblies are not being displayed. They are loaded but the only way to display them in the upper level is to change them globally to entire part the n change back to SOLID. This works perfectly but i am curious to see if anyone else has had this problem.
Thanks in advance
Thanks in advance
RE: REFERENCE SET HELP
Assy should load fine
This does seem strange behaviour, especially if it's intermittent. You mention a global change to ref sets... if a parent assembly needs to have its ref set changed for you to see the child sub-assemblies then these would not have been originally loaded (as they are considered excluded).
What do the checkboxes of the component nodes contain when you load the assembly? Are they red checks, grey checks or blank? What is the reference set of the parent assembly of these components that aren't loading?
As Mark mentions - check your Default Reference Sets available from the "File -> Load Options" dialog.
-BB-
