Labyrinth seal (bearing seal)
Hi All Dears:
I would like to know some detalis about Labyrinth seals in water pumps.How much is the radial gap (between housing and seal)in this type of sealing?whether this type seals is prefered to contact seals for oil lubrication?
RE: Labyrinth seal (bearing seal)
I think the clearance(between housing and seal) of labrinth seal is D/2000,D is shaft diameter.
A labyrinth seal, at a minimum has to have enough clearance to permit the shaft to move however much the bearing clearances permit the shaft to move.  Shafts move for a variety of reasons, bearing tolerances, or lubrication wedge thickness in the case of journal bearings, or vibrations, deflections in the pump, and more.
In any case, the shaft does not want to touch the seal, because that damages the seal, wearing off the sharpness of the teeth that is an integral part of the sealing process (sharped edge orifice concept) and creating hot spots that cause shaft bowing, causing more wiping, and more damage.
Inside of those parameters, they are used with great success in a variety of rotating machinery, pumps included.
If used with steam turbine drives, leaking steam from the turbine seals can enter the bearing cavity, so that has to be considered.  This applies to any atmosphere surrounding the pump that would be detrimental to the internals of the bearing/lubrication system.
I hope this gives you a few details to ponder, while my peers come up with still more, maybe.
rmw
Dears:
In fact for design of a labyrinth seal in a water pump I search for the amount of gap (radial or axial) between rotary and stationary parts in an application with 1500 rpm and oil(SAE 30)sealing(bearing lubrication. can you help me? is this type of sealing useful?
