Water testing for hot water heating
I am looking for information on water testing requirements to be done for an industrial hot water heating system? If any one has information on where I can find guidelines for chemical addition and or typical hot water heating chemistry program plus typical water testing done on such a system.
Thank you
WTP03
Thank you
WTP03
RE: Water testing for hot water heating
WTP03
Thank you for the information. If the make up water is not softened what would be a suitable chemical program to follow with low amounts of make up? Also I will be talking to a chemical company regarding this but I would like to have as much info. prior as possible
Thank you
WTP03
In this mode you will likely need a scale inhibitor and dispersant.
You are going to have to make the call after visiting with your chemical treatment consultant/supplier
