C Programming with ATtiny12
Somebody knows how programming ATtiny12 in C language because when I compilated my code WinAVR said "ATtiny12 is not supported by the compiler" and I don't enjoy to learn assembler just for a little programm.
Thanks.
RE: C Programming with ATtiny12
I suggest write your program in e.g.  BASIC and find someone who can "translate " it...
<nbucska@pcperipherals DOT com> subj: eng-tips
ATtiny12 is supported by WinAVR but in assembly code only not in C. I have the lastest version, so ....
But I've found another solution : a ImageCraft software called ICCTiny.
Great for all ATtiny, it support C without problems.
If it is a one time application, it may be worth to use a
more expensive processor to simplify the programming e.g.
a PC compatible one for << 100.- USD.
