Corrosion Engineering Courses On Line/Distance Learning
Hi can some one suggest a good Corrosion Engineering Course, On Line/ Distance Learning (well Recognized  in the industry).
Thanks in advance
RE: Corrosion Engineering Courses On Line/Distance Learning
Here are three areas you need to investigate for you studies.  They are considered the one of, if not the best courses.  You can probably best navigate from the first link.  The second two are specific for corrosion.
Also look at other courses on the site.
http://www.asm-intl.org/Template.cfm?Section=Training&NavMenuID=76
http://www.asminternational.org/Content/NavigationMenu/Training/OnlineTraining/OnlineTraining.htm
http://www.asminternational.org/Template.cfm?Section=BrowsebyFormat&Template=Ecommerce/ProductDisplay.cfm&ProductID=10586
