hmm replace text using a file??
well i hit it you know that brick wall we all hit while working my little add to text and export text is great untill i have to replace the existing text from either an excel spreadsheet or a comma delimited file that contains either the text handle, original text, new text or original text,and new text. if someone has already hit the same wall as i and would be so kind to help it woul greatly be appreciated i woud develope it myself but i have a project due shortly and im currently searching the web for something that will surfice for now and btw if it was just 20 or so lines it wouldnt be so bad but its 4,233 different lines of text that may or may not reoccure through outh the drawing so tigrek if you happen to see this let me know if you already have done something like this i know you do alot wiht excell anyway later people.
if everyone helps everybody the world will be a better place
