Connections>Interfaces
What is the use for Connections>Interfaces in Mechanica Wildfire?
If you have two shelled sections (forming a 90degree angle) that do not touch once shelled, I would presume that the use of Connections>Welds>End Weld still applies...
Many thanks for your help.
