Minimum Frost Depth Northern Michigan
Can someone tell me either the minimum frost depth of footers and footings for northern Mighigan?
OR
An online site where I might find this information?
Thank you.
OR
Thank you.
RE: Minimum Frost Depth Northern Michigan
Anytime I've had the same question for various areas around the country, the local inspectors have been very helpful.
If you need "actual" frost line local plumbers or dirt work companies may help.
Good luck
As a start, according to NAVFAC DM-7.1 pg 7.1-42 it's 5'.
HTH
VOD
