Corrosion rate of tin coating
Hi!
I'm trying to find information about the corrosion rate of tin coating, especially in seacoast atmospheres.
Does anyone know where I can find that information?
Thank you beforehand.
Richard
Richard
RE: Corrosion rate of tin coating
Depending on the quality level of the tin coating, I found a reference that provides corrosion rates of tin (this would be tin metal) in a marine environment. The corrosion rate over a 10 year exposure period was 9 mils/year (page 166, "Corrosion and Corrosion Control", by UHLIG). Keep in mind this is for tin metal and if a coating could be applied that is solid tin, you could probably use the corrosion rate listed above. Otherwise, a tin plate that is not properly applied or contains small pores will probably suffer the same fate as the tin plated can.
The key I believe is to have a dense layer of tin coating so that tin acts as the anode and corrodes versus the substrate material.
Richard
