Why can't I delete these lines!?
Some times in inventor, I am unable to delete projected lines in sketches. Why is that and is there any way to get rid of them?
RE: Why can't I delete these lines!?
Select them then change them to normal or construction.  Then delete them.  If it's an adpative projection delete the reference in the browser.
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Autodesk Inventor Tutorials & More
