Supplier for direct-bearing hardware
I'm in the process of designing & constructing a low-profile deck. The dimensions of the deck and local codes will require that I use 2-2x8 pressure-treated lumber for the beams which need to be connected directly to the concrete footings. I also need to provide 1" standoff from the footings. Does anyone know of a fastener for this type of arrangement and a supplier?
Simpson don't make anything of the correct dimensions, their post anchors only work for 4x4 (3 1/2" actual) lumber or larger, I need 3" actual.
TIA
TIA
RE: Supplier for direct-bearing hardware
Cheers
http://www.strongtie.com/products/categories/beam_seats.html
