Making a fixed-size screen grab
Does anyone know if it is possible in V5 to make a fixed-size screen grab?  I have been up and down the Tools > Image > Capture and can't seem to get anything to happen.
Thanks.
RE: Making a fixed-size screen grab
Do this:
tools/image/capture
on the capture window:
click Red dot icon <capture>
on the capture preview window:
select the format/target directory, using the save as icon
even simpler if running w2k:
press print screen key.
open your favorite graphics application
edit+paste
cheers
AXXX,
I have done things like you suggested before.  What I'd like to do is specify the size of the capture, like 2" x 2" or 400 x 300 pixels.  I'd rather do things this way than have to keep going to other graphics programs and cropping my images, which I have been doing.  I use Capture and the Print Screen key frequently.
Thanks.
hi again,
that is a simple operation
do this instead:
click on the capture options on the 2nd step below
pixel tab
rendering quality-> custom
More
Define your size in the Image size window
cheers
AXXX,
I have done what you mention, but to no avail.  I believe I will literally need a step-by-step after you change the size, because I have never had success in this area.
Thanks.
