Need Help bonus tools not working!
I recenly reinstalled my autocad 2002 and for some reason I can't get the bonus tools to work. is there a way to make all the contents of the bonus tools function properly. for instance when I try and turn a layer off it simply says it doesn't recognize the command and to press f1 for help.
Toro
Toro
RE: Need Help bonus tools not working!
Since you say you reinstalled AutoCAD, did you remember to put the Bonus Tools folder back in the support files search path?
Just a thought.
Haggis
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
