maintenance checklist
can anyone help me in finding out maintenance chcklists for HT panel, MCCs, Transgormers, DG sets, Pump-motor sets etc.
i want to prepare maintenance checklist like
HT panel--> parts to be checked---> remedial action required
RE: maintenance checklist
Section 7 of www.netaworld.org/Category.cfm?CategoryID=26 is very good information, but applying resolution to problems found is not so easy—that's what experience provides.
Hi psozot
You will find all the service checklists and remedial actions in the manufacturers manuals.This is a quick way to start your scheme,these manuals will also advise you on fequency of inspection.
Try NFPA 70B, "Recommended Practice for Electrical Equipment Maintenance"
Suggestion: If the maintenance check list it meant to be for larger facility, e.g. Nuclear Power Plant, larger manufacturing plant, etc., the industry standards, e.g. NETA, will be somewhat customized (beefed up).
