screw conveyor, cuting plan of blade
Dear all,
We have a sectional blade of screw conveyor
The dimension is :
Inner diameter 88.9 mm
Outer diameter 229 mm
Pitch 229 mm
Does anybody knows how to draw the cuting plan of that sectional blade ?
for information, cuting plan drawing is a drawing for worker to made ( work order drawing )
Thanks before
The dimension is :
Pitch 229 mm
Thanks before
RE: screw conveyor, cuting plan of blade
I already used phytagora's formula to find out the dimension for the cuting plan drawing but after we have cut from the sheet, the shape does not good enough compare with design shape and dimension.
Thank's for your kindly help
Good luck
Patrick
