Cincinnati Press Brake FormMaster 2
Having promblems with consistancy of forms on a Cincinnati form master 2 press brake. Cincinnati service people can not find the problem, was wondering if anyone else has had any troubleshooting expirience in this area. 175ton press with heavy duty backgage making 6 bends in 1/4" gal. steel. Backgage is accurate, and sometimes finished part is. Then again sometimes the part is off .030". It's not the operator, doesn't make a difference who runs it. Any help is apprieciated.
RE: Cincinnati Press Brake FormMaster 2
What kind of shape is your tooling in?
How well secured is the die?
Griffy
Thanks!
When you say "off .030" do you mean individual bends are off by that much or that a feature affected by 6 bends is off that much (cumulative)?
Griffy
