Fixtogether in Assembly help
I am checking how the fixtogether tool works in the assembly, but I cant get it. After fixing two elements, I allways can move separately every element. They are not fixed although I can see the fixingtogether symbol in the constraint tree.
Of course, when I try to move one of the fixedtogether elements a warning window displays, but I would like to know why the elements are not really fixed.
Best Regards and thanks to everybody
Antonio
Antonio
RE: Fixtogether in Assembly help
Also check to see if one of the parts has been fixed in space.
Thanks for your answer but I cant get it. After moving one of the componente fixed together the Update symbol remains gosthed. So, there is nothing for updating. I have checked there was no prior element fixed.
Any suggestion?
regards
Antonio
