insuffisant memory with macro!
Im executing macro on CATIAV5R11, and this takes many hours to be executed completely. but befor the end, the computer shows me a message: insuffisant memory. the probably cause of this is that CATIA keep on memory all the steps made by this macro, so is there any one who know if I can change some options to ovoid this problem.
thanks.
thanks.
RE: insuffisant memory with macro!
Also does the script run okay on a smaller product.
Look at your code and see if there are any ways that you can stream line it.
Check to see if you are re setting parameters inside a loop that does not need to be.
See if you can use Search commands instead of loops for selecting geometry.
I used this technique in one my scripts and it greatly increased the speed that it ran.
my code is ok, but what do you mean by cache setting, I kept my default setting of CATIA
