IN 100 on IN 100 wear characteristics
I'm looking for info on the wear characteristics of cast IN 100 on cast IN 100 at elevated temperatures, from 500°F to 1900°F. I'm hoping I won't have to apply a wear coating for a test that lasts under 500 hrs over the specified temperature ranges with low stresses, under 10,000 psi.
RE: IN 100 on IN 100 wear characteristics
Alternativelky, you should consult published information on similar materials.
I think it is hard to find wear data for special materials, particularly for elevated temperature conditions.
