Arc and TIG electrodes
Dear All:
I would like to have your oppinion regartding one issue:
Today it happened that I saw one of my guys in the workshop taking out the outer shield of a electrode for arc welding. I got curious and I ask him why. His answer was that he needed to weld TIG and since there were no more TIG electrodes, he removed the outer shield of a arc electrode, with the justification that the core of a electric arc electrode is the same of a TIG electrode. I never heard anything similar, but since the guy is so experienced, I trusted him. But I wanted to confirm with you guys if it is true that the core of the electric arc electrodde is similar or equal to the TIG electrode and what are the risks of such practice.
Thanks a lot
PR
Thanks a lot
PR
RE: Arc and TIG electrodes
This is a practice that should not be continued. First off, filler metals for arc welding are specially formulated and require the use of the flux coating to meet the intended mechanical property requirements for the weldment. Stripping the flux coating and simply melting the rod into the base metal using the GTAW process will result in a weldment that has unpredictable properties and performance.
Thanks a lot for your feedback. I will stop this practice immediatelly.
PR
