Heat load calc- Gas engine
I am trying to calculate the heat load given off to the surroundings from an 8 HP internal combustion engine. ASHRAE looks to give a formula for an electric engine but not a gas engine. Also, what type of efficiency would you expect (lawnmower type engine). Thanks.
RE: Heat load calc- Gas engine
as far as efficiency, perhaps 25% or so.
good luck!
-pmover
