Drawing as a template
Has anyone figured out how to use a drawing as a template/master?
For example I have 6 variant CATProduct for 6 exhaust line - the differences are at the inlet end only. I also have 1 completed CATdrawing with all the views, notes + dimns I require.
The obvious Edit..Links fails with 'view refuses link'
RE: Drawing as a template
Good Luck!!
My mistake was to use 'New from' on the CATProd & CATDraw, then replace component.
If I open the draw and product, do the replacements, then use 'Save as' the draw retains the links and updates - a good solution.
But are there any pitfalls in using 'Save as' for these unique assemblies? Am I correct in saying all 6 products will have the same UUID?
