Cna we compile VBA codes
Please I need somebody to talk to me about this. I have some spreadsheet models that where built on VBA codes, I would like like to compile them so they can be run outside Excel, can this be done?
Greg Akhibi
ABB Lumus Global
RE: Cna we compile VBA codes
To run this code standalone you should get a copy of visual basic.
But provide the original code author used true VB coding, rather than relying on VBA functions and commands then it is a relatively simple job to extract and compile the files directly using VB ... as the other respondant has already indicated.
claims to offer that sort of functionality, but I'd have to say that the website looks a tad prehistoric.
A google search on the obvious terms threw up plenty of hits, one promising one in particular needing asubscription. You might try asking on tek-tips.
Cheers
Greg Locock
