Satellite heat pump coil- does it exist?
I picked up a Carrier satellite heat pump (38BK024300 2-ton) at a local salvage yard.  I wanted to know if anybody has heard of a heat-pump coil that would work woth this unit.  Normally it goes with these whigh wall mount satellite fan coils.  I would like to utilize this heat pump with a traditional duct-line coil.  Any suggestions?
Thanks!
RE: Satellite heat pump coil- does it exist?
If no results here then try here:
http://hvac-talk.com/
