shot peening of aluminum alloy
Does anyone do shot peening on aluminum alloy?
If so, particularly what part (application) is shot peened?
And what type of peening media is used?
RE: shot peening of aluminum alloy
http://www.shotpeening.org/ICSP/confrns.htm
http://www.shotpeener.com/
http://www.metalimprovement.com/
It was very helpful.
http://assist1.daps.dla.mil/quicksearch/
Shot peening of Al alloys is commonly performed on aircraft parts to be hard anodized. The shot peening induces residual compressive stresses to compensate for the decrease in fatigue life due to the relatively brittle anodic coating. Common applications are hydraulic cylinders and pistons. All shot peening residues are chemically removed prior to anodizing. – MIL-S-13165C, paragraph 3.3.10.2; MIL-P-81985, paragraph 3.5.2.1. Nitric acid-based solutions are used.
Shot peening can also eliminate anodizing defects due to the presence of primary solidification intermetallic phases.* The shot peening breaks up the intermetallics within the near-surface Al matrix to a small enough size so as to not blister the subsequent hard anodizing, and is a common procedure for helicopter manufacturers. – personal discussion, Leah Markowitz, HR Textron, 1998 SUR/FIN conference.
*These can occur in diameters comparable to the hard anodizing thickness in castings and forgings of high strength alloys such as 2024 and 7075.
Some useful literature articles:
“Effect of Shot Peening Variables on Fatigue of Aluminum Forgings,” Metal Progress, v. 120, No.2, p. 33-35 (1981) and
“Hard Anodic Coatings on Aluminum Alloys: Evaluation and Control of Porosity,” Metal Finishing, p. 19-24 (December 1992).
we used to peen swingarms for motorbikes and inlet manifolds for racing cars. Basically it was to give a good surface finish and remove any ....ahem suface defects.
on the other hand shot peening of Aerospace castings was a definate No-no. the reasoning beyond this is that you would peen over any surface defect and hide them, despite the fact that they were being xrayed.
i would say in general its done for cosmetic reasons.
