cap start & run reversing single phase problem
I replaced a 7 1/2 hp weg motor,i am having the same problem as the original one. the start cap is blowing up.
This motor is used on a Right Way power winch, with momentary push buttons for up and down.
The customer jogs the buttons when they get close to where they want to be.
The controls are wired with one line going right to the motor?
Motor windings have 1-2-5 & 3-4-8
Centrifugal switch also burned together
thank you
thank you
RE: cap start & run reversing single phase problem
The start capacitor has no time to cool off and they are also rated in the numbers of starts per HOUR!
The start switch too will get too hot and weld itself together!
Your typical motor can't take that kind of abuse for long!
You may get away with DOUBLING the capacitors rated voltage and changing out the start switch with a heavier duty one.
If that fails to help, a motor designed for that kind of abuse may have to be acquired.
Our experience leads me to suspect your centrifugal start switch may be a problem. None of the manufacturers have great centrifugal switches, and Weg's is near the bottom of that list.
Our company policy allows use of single phase motors only if there is no jogging, no frequent starts. The centrifugal switches from any manufacturer will be a problem. Jogging is tough for any single phase motor.
You can easily in just 1 hour or less convert your motor over to solid state starting switch or potential relay to replace the centrifugal switch. Depending on how much you jog, that may solve your problem.
As SteveKW pointed out also, if your jog frequency is very high, your start caps may heat up.
PUMPDESIGNER
