Rotate Text in Sketch
I'm using SW 2004. I'm putting stamped part numbers on my parts. I've successfully created the text as a cut.
How can I rotate the text in the sketch? When I right click on the text and use the rotate button all the text slants. It will not rotate the whole line of text.
Matt
Matt
RE: Rotate Text in Sketch
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
This is also the way to position the sketched text.
Scott Baugh, CSWP
FAQ731-376
Pete Yodis
