Nickel removal from chemical waste water
Dear my colleagues,
I am working an automotive plant and responsible from treatment plants. Nowadays, The amount of Nickel and Zinc comes from paint shop to the chemical waste water treatment plant increased. Nickel and Zinc produces at phosphate plating process at paint shop. I would like to remove Nickel and Zinc before treatment. So does Anybody have information about removal of nickel and zinc before treatment. Is there any material to filter heavy metals.
Thank you for your kindly support.
RE: Nickel removal from chemical waste water
It is possible to remove heavy metals from wastewater. However, you may produce a sludge that contains heavy metals. You may then have a sludge disposal problem.
Do you have an analysis of the wastewater? What is the conductivity (TDS)level of the wastewater?
Todd
www.oxilume.com
Thank you for your answer. My main problem is the amount of Nickel and Zinc at treatment sludge. Because of the high heavy metals I should pay more money for disposal. My idea is; If I remove nickel and zinc before treatment,I can solve the problem.
Two types of water comes into Chemical treatment plan. These are Metallic and oil bases. Nickel and Zinc inside of Metallic bases. Its conductivity is; 140 µs/cm at 19,5 C degree temperature.
I am looking forward to your answer.
GoTo the following website: www.oxilume.com
Look on left and click on HotSlide.
My contact information is on bottom of each page.
Todd
www.oxilume.com
I know they have some plating waste stream experience, so you may want to give them a call to check your particular stream.
(303)-833-1432
www.octolig.com
Good luck.
You can contact me at pmorton@ecsrefining.com. If you send me the concentration data with discharge goals, I will see what I can do.
Peter
