applying materials to a loft face
I have a problem with applying different materials to two faces of the same loft. When I apply let's say chrome to face 1 of the loft, both faces turn chrome instead of face 1 being chrome and the other one staying the same as before.
I have similar problems with other faces too. Often when I try too apply a material to a face it doesn't render, but if I extrude the same face 0.001 mm and then apply the same material too the feature it renders perfectly.
I'm doing this work for my for a college course although I've done some work in SW before.
/Staffan
SolidWorks 2003 with PhotoWorks
nVidia GF Ti4200 128mb, 56.64 driver
768 Mb RAM
I don't have a SP installed for SW
WinXP, SP 1
/Staffan
768 Mb RAM
WinXP, SP 1
RE: applying materials to a loft face
How did you make the loft?
I tried it 2 ways
1) I made a square and trangle and changed a single face - No problem.
2) I made 2 circles different sizes and used a guide curve. Again no problem adding a chrome material to a face.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Anyways, now I have another problem.
I made an assembly with a torso (part) and a left arm (sub assemby). I then mirrored the arm to get a right arm. Here's where the problem starts. The mirrored assembly does not retain the materials of the left hand part and since I'm having troubles assigning materials to faces, I can't get the right materials on the right hand part.
Scott Baugh, CSWP
FAQ731-376
