UG NX Information window
How to change the default settings for the information window like font style,font size etc..
The default font looks like "Times new roman"
How to change this to other fonts
RE: UG NX Information window
I Know one solution, but it is related to a particular user...
1) Open a any Part file.....
2) Go to Help-->Click Unigraphics Log File...
3) An Information Window will pop up.....in that Check for the Defaults file " UGII_DEFAULTS_FILE"
4) Opposite to this you will find the path of the Defaults file, which is located in your Installing Folder....
5) Open the *.def file as a Notepad....
6) In that file, change the defaults settings as per your requirement & save as that with new name...
7) Now right click the mycomputer--> go to Environment variables...
8) IN user set variables give variable as UGII_BASE_DIR & value as a path of the new save as file....
then close all the programs related to UG & open the UG once again....
ss
I tried the default file but I could not find any settings for the information window.
Any help please?....
