License timeout for Catia v5 after inactivity?
With Catia v4, I can set it to timeout and release the license after a period of inactivity by using a combination of catia.MAXTIM_MSG and catia.MAXTIM_WAIT.
I've been searching through the documentation, but I can't seem to find anything in Catia v5 that can be set so that a session will die and release the license after inactivity. Is there such a beast?
Tracy
Tracy
RE: License timeout for Catia v5 after inactivity?
Starting from R10 (if my memory is not wrong), the time_out mechanism is available in V5.
Tools + Options + General + Disconnection
Check the option "Automatic disconnection after ... minutes"
It lets you activate automatic disconnection of your Version 5 session after a user-defined duration (in minutes) without program use.
Cheers. Kennis Tang.
